    Converting Texture to geometry
    5 Posts 2 Posters 588 Views 2 Watching
    • R
      rspierenburg
      Just wondering if anyone knows of a plugin or tool that allows one to convert a texture (or image) to a sketchup mesh. I'm looking to get into architectural 3d printing and for things like brick textures I looking to print something with physical texture. I know I can go into sketchup and model each and every grout line manually but I was hoping there was something to convert say a displacement map to geometry.
      Thanks,
      Robert
        If you can take your texture image and make it a gray scale image you could probably use Bitmap to Mesh by ThomThom to create the mesh. Just be aware it can really load up your model file.
        https://sketchucation.com/pluginstore?pln=tt_bitmap2mesh
          Here's a quick example using one of the OEM brick materials. Mesh on the left.
          • R
            rspierenburg
            Thank you so much. I definitely need to get some settings figured out because everytime I tried it it crashed my Sketchup instance. I'll keep going.
              What is it you're doing when SketchUp crashes?
              FWIW, when I model for 3D printing I set Units to Meters and model as if millimeters are meters. This allows me to model fine details and to create smoother curves. The slicer I use imports .stl files as millimeters but I export the .stl with model units (meters). For examples see my thread on 3D printed screw threads in the 3D Printing forum category.
              Keep in mind that adding a mesh from a an image like the brick texture I used adds tons of geometry. This can slow SketchUp quite dramatically depending on your computer's CPU and GPU. You might get frequent messages of "Not Responding" which normally isn't a crash. Just that SketchUp is busy and won't respond to further inputs from you until it is done. It might be that you'll need to break your model up into smaller sections and assemble the printed modules when they are complete.
