    Flatten panels for tent pattern
    4 Posts 2 Posters 108 Views 2 Watching
    • K Offline
      Kusalo
      I have been using S'up for many years but would hardly consider myself an expert. I have been doing mostly small architectural and furniture modelling. And now I am planning several lightweight hiking tents. There is curvature involved and I have been using Fredo6 Curviloft with good results.
      I have been using Alex Schreyer: Unwrap and Flatten Faces which also works well, dropping a panel to ground.
      Currently using s'up version 20.
      Also have s'up Make and my old trusty ver 6.4 from 2007
      The problem is translating a S'up panel into a full-size pattern.
      I draw a rectangle: 800x333mm at 0, 0, 0
      Camera: top view
      Export as dxf/dwg (full size) and get a rectangle 544x226 – which is correct proportion but ain't 800x333. And of course it gets more complicated with irregular shapes. Perhaps there is a consistent scale that I can set when importing (into Illustrator)?
      The other option is to dimension the life out of the flattened panel and manually draw it (yawn).
      I am just getting started with this so would be really interested to hear any suggestions.
      Thank you.
        Please update your forum profile to reflect that.
        Camera: top view
        Sounds like you're missing a step. Not only do you need to set the Camera to the Standard view but you also need to set it to Parallel Projection.
        • K Offline
          Kusalo
          @Dave...
          I see that it makes a perspective difference. Thanks for that.
          Profile updated.
          I have done quite a range of tests and have a consistent import scale of 147.05% coming into Illustrator. Why? Am I missing something else?
          I found that putting a bounding box around my test shapes helped test the sizing accuracy – and give me some confidence. Although I am still not locked into a process.
          Has anyone worked with export for pattern printing?
            Share the SketchUp file so we can see what you are working with. Maybe it would be better if you were using LayOut and exporting from there.
