    How to curt hole in log wall
    28 Posts 4 Posters 2.4k Views 4 Watching
    • ntxdaveN
      ntxdave
      I know this is a really dumb question but I am having trouble cutting a whole for a door or window in a log wall. Here is an rough image of the wall type I want to cut holes into for doors or windows. When I try to do it, I have the wall as a group which is made up of a number of groups which are the logs. I am getting messages about the number of groups. Advice on how to do this correctly would be appreciated. Yes, I know this is a dumb question..........
      Here is the simple skp file......LogWall.skp
      Press F1...thank me later
      • Gus RG
        Gus R
        I usually subtract (solid tools) each group one by one while repeatedly pasting in place what I'm subtracting. If what's being subtracted is just repeating you can use a component instead of a group and then you only have to do it once and then make the component unique say for the header where it may not need to subtract the entire log. I see you also have a solid there which I'm assuming is a door and that has to extend beyond the front of the door. I always like to extend the solid beyond the limits of what I'm subtracting since if it's right on the edge it will result in a mess.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • ntxdaveN
          ntxdave
          Thanks for the reply Gus. I did not realize the object was hidden behind the wall. Here is an updated image that (I think) does a better job of showing what I am trying to do and what the results are.
          I am not 100% sure I understand what you were telling me to do. πŸ˜•
          • Gus RG
            Gus R
            If you open the attached example you can see how I created unique components for each log that's have identical openings. The white ones are unique. If you create a component you only have to cut that log once wherever there's an opening. With a group you have to cut them one by one.
            Log Cabin Cutout Sample.skp
            • Gus RG
              Gus R
              See attached example. It's in version 8 for anyone else to take a look.
              • ntxdaveN
                ntxdave
                Gus, I am feeling really stupid. I open your model and do not understand how you cut the holes/sections for the logs. I tried doing it with only one log at a time and got the same message I showed in my last post. What the heck tool did you use to cut the logs?
                I have used SU for several years now and have not had this problem before. πŸ˜• πŸ˜•
                • Gus RG
                  Gus R
                  I'm using the native solid tools. Should be the fourth icon that says "subtract" on mouse over.
                  • Gus RG
                    Gus R
                    First you select the solid you want to subtract. Then click on the subtract icon and then click on one of the logs.
                    • BoxB
                      Nested groups are not solids, so your group of groups cannot work with solid tools. You must either explode the log groups into the parent group or explode the parent group and do multiple subtractions, one log at a time.
                      You also have an extra couple of misaligned logs at the bottom.
                      So here in this gif, I delete the extra log, explode the log groups creating a single solid then subtract the 'hole'. You could regroup your logs after, loose to groups would do it in a click or two.
                      https://i.imgur.com/CPWWdQa.gif
                      • ntxdaveN
                        ntxdave
                        Ooooh how dumb am I, I was using the subtract wrong. Now, another dumb one: if I want to subtract from multiple logs, do I have to recreate the subtract object for each log one at a time? Is there a way to subtract from multiple logs at once?
                        • BoxB
                          Use Trim.
                          • ntxdaveN
                            ntxdave
                            Ooooooooouch - Box that is to simple! I am feeling dumber by the hour. πŸ˜’
                            • BoxB
                              It's worth noting that this Trim function is broken in 2023, you have to reselect the tool each time.
                              But I suspect you aren't working with 2023 anyway.
                              • ntxdaveN
                                ntxdave
                                You are right. I am using 2020. πŸ‘
                                • Gus RG
                                  Gus R
                                  Don't worry. I was stumped with the subtract tool at first since I was using Bool Tools for a long time.
                                  • ntxdaveN
                                    ntxdave
                                    Box, what is the tool on your toolbar next to the eraser (the one you clicked on to delete the object you used for the trim and subtract functions)?
                                    I was going to try to modify my main toolbar to include that tool but I cannot seem to get to the option to modify a toolbar. I cannot get the ability to edit a toolbar to show up.
                                    BTW: I tried both of the options that you showed in your videos and got them both to work. πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                    • BoxB
                                      That Icon is Delete from the 'Standard' toolbar.
                                      This thread has a gif showing how to make a custom toolbar from about 9 years ago.
                                      https://sketchucation.com/forums/viewtopic.php?f=15&t=59701&hilit=+toolbar#p543863
                                      • N
                                        numerobis
                                        You could also use Eneroth Solid Tools which support preselection of multiple objects...
                                        https://extensions.sketchup.com/extension/b1fc993f-42ac-44ab-8655-3037ccdfc36e/eneroth-solid-tools
                                        • ntxdaveN
                                          ntxdave
                                          Thanks for the link but I could not find a toolbar that had the delete icon.
                                          Thanks for the link. That plugin is not available via the Sketchucatiob Plugin store.
                                          • Gus RG
                                            Gus R
                                            Thanks Box. I finally expanded my use of Sketchup's solid tools. Got stuck in a routine.
                                            • 1 / 2
