    Toposhaper Error 2.6v
    1 Posts 1 Posters 82 Views 1 Watching
    • D
      dm_08_ Newcomers
      Toposhaper 2.6 error Sketchup 2022 pro
      How can i fix that?
      Date: 14-Sep-23 11:08:57
      An error occurred in CLEANSING
      The operation is fully aborted
      cannot hide layer that is a part of the active path
      body_lib6tool.rbe: 2538 -- visible=
      body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
      body_lib6tool.rbe: 2537 -- each
      body_lib6tool.rbe: 2537 -- switch_to_temp_layer
      toposhapertool.rbe: 1391 -- change_view
      toposhapertool.rbe: 1358 -- set_preview_working
      toposhapertool.rbe: 544 -- cleansing_processing
      toposhapertool.rbe: 523 -- after_selection
      toposhapertool.rbe: 493 -- notify_edge_picked
      body_lib6edgepicker.rbe: 539 -- call
      body_lib6edgepicker.rbe: 539 -- notify_action
      body_lib6edgepicker.rbe: 582 -- terminate_current_selection
      toposhapertool.rbe: 658 -- execute_validate
      toposhapertool.rbe: 387 -- handle_initial_selection
      toposhapertool.rbe: 319 -- activate
      toposhapertool.rbe: 133 -- select_tool
      toposhapertool.rbe: 133 -- action__mapping
      data6.rb: 65 -- call
      data6.rb: 65 -- launch_action
      lib6plugin.rbe: 240 -- launch_action
      bootstrap_toposhaper.rbe: 83 -- launch_action
      bootstrap_toposhaper.rbe: 149 -- block in startup
      lib6plugin.rbe: 1469 -- command_invoke
      lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
      lib6traductor.rbe: 1387 -- block in add_command
