    Edit_transform not available in the C-API?
    3 Posts 2 Posters 511 Views 2 Watching
    • P Offline
      Hey folks,
      SketchUp offers the edit_transform instance model for the model: https://ruby.sketchup.com/Sketchup/Model.html#edit_transform-instance_method - However, it seems that there's no equivalent in the C-API. I checked the documentation of the SUModelRef: https://extensions.sketchup.com/developers/sketchup_c_api/sketchup/struct_s_u_model_ref.html.
      Am I not looking in the right place, or is there an alternative way to get the edit_transform?
      Cheers,
      Thomas
      • Dan RathbunD Offline
        Dan Rathbun
        The C API is mainly written to act upon files.
        There is only some limited things you can do with "live" models.
        Currently, the C API cannot be used to modify the active model.
        You can get the active edit path via: SUModelGetActivePath()
        ... and from it the transform via: SUInstancePathGetTransform()
        I'm not here much anymore.
        • P Offline
          Thanks, Dan, for the information! I solved it in my code by having a ModelObserver, implementing onActivePathChanged, and passing it to my C-extension code.
          Even though you cannot modify the active model, you still need to know the edit transformation for some cases. If a user opens a model to edit, if you query the instance transformation, it will be a world-coordinate transformation instead of a transformation relative to the parent. My C code assumes transformations relative to the parent, so I must calculate that using the edit transformation. You probably already knew this, but I'm putting it here for posterity.
          Cheers,
          Thomas
