    Help repairing 2d model
    5 Posts 2 Posters 243 Views 2 Watching
    • E Offline
      evodoula
      Hello,
      I've been using Sketchup Pro for around 12 years for landscape design. In the last few months, I've been having trouble closing faces on 2d base plans, and I don't know why this is happening after years without problems. Might someone be willing to have a look at the file and see what's going on? I've attached the file, and here's an alternative link: https://www.dropbox.com/scl/fi/iwshkr9ux2j3zig7cdim6/Soderquist-base-plan-try.skp?rlkey=ismuv9txnhf5b538hcuw2dlxl&dl=0
      Thanks so much!
      B.
      Soderquist base plan try.skp
      • Gus RG Offline
        Gus R
        Try flattening it first. If you look at a side view of the plan in parallel projection you can see that the line work is in different elevations. I use Vertex Tools to flatten but I know there's other techniques which someone else around here can describe. Flatten then put it all back at Z = 0.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • Gus RG Offline
          Gus R
          Go to Extension Warehouse and search for "Eneroth Flatten to Plane." Use that. Just tested it and it work like a charm.
          • E Offline
            evodoula
            Thank you, @Gus R. That did take care of most of the issues. I'm puzzled as to why this has been happening to me recently; I didn't change my work sequence. Sure helps to have a corrective tool. All the best to you. B.
            • Gus RG Offline
              Gus R
              Hard to tell what caused it. I did a site plan which was just a quick tracing of an existing site plan and then made the mistake of plotting a PDF in perspective instead of parallel projection and the whole thing was off. A slight perspective view might throw things off. Any little object with a positive or negative z value.
              I use flatten.lsp in Autocad to flatten all line work most of the time. This is especially useful when you're drawing over a survey with topography that can be thousands of feet above the ground plane. Even a 3D door will do the same when snapping lines. I'm still old school with Autocad using what's basically a modern version of Autocad 15 and 20 years old. Works great.
              Non-planar faces in Sketchup can also create a mess.
