    Group dimension
    8 Posts 2 Posters 497 Views 2 Watching
    • robertWanR Offline
      robertWan
      Is there a plugin that displays the dimensions of a group after selecting it? I'm looking for a simple way to make a list of furniture items. I know that there are extensive plugins that make a list to a file.
      Robert
        There was an old one that does this:
        Is that what you are wanting?
          robertWan
          Yes, only I will use it by selecting individual groups (or components) that the furniture consists of.
          Robert
            robertWan
            I found this one, I think:
            https://sketchucation.com/forums/viewtopic.php?f=323&t=28851
            There's only one catch... there is no icon, but maybe a keyboard shortcut will help.
            Robert
              It works on individual components, too.
              if every plugin you installed had a toolbar there'd be no room to display your model. Either access it from the Extensions menu or set up a keyboard shortcut.
              Question: Are you planning to go through your model and manually get the dimensions of each component or group? That sounds like a lot of work.
                robertWan
                So I did.
                I have control over what I want on the list.
                I know that there are dedicated plug-ins for lists of elements, but I think this simple solution will work. There is a small problem.
                There was probably a plugin that aligns such a rotated group. But that's a detail and probably won't bother me.
                Or is there a simple way to modify the code?
                # Copyright 2005, CptanPanic
                # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                # Name        ; GetDimensions.rb
                # Type        ; Tool
                # Description ; Displays Dimensions of Component.
                # Menu Item   ; Plugins -> Get Component Dimensions.
                # Context-Menu; None
                # Author      ; CptanPanic
                # Usage       ; Select Component, and call script.
                # Date        ; December 2005
                # Version     ;	1.1			2014 compatible
                # History     ;	1.0			Initial Release.
                #             ; 2010-06 <jim.foltz@gmail.com>
                #               returns "true" dimensions for rotated and scaled Group and Instance.
                require 'sketchup.rb'
                module JF
                  module GetDimensions
                    VERSION = 1.1
                    def self.get_dimensions
                      model = Sketchup.active_model
                      selection = model.selection
                      ### show VCB and status info...
                      Sketchup;;set_status_text(("GET COMPONENT DIMENSIONS..." ), SB_PROMPT)
                      Sketchup;;set_status_text(" ", SB_VCB_LABEL)
                      Sketchup;;set_status_text(" ", SB_VCB_VALUE)
                      ### Get Selected Entities.
                      return unless selection.length == 1
                      e = selection[0]
                      return unless e.respond_to?(;transformation)
                      scale_x = ((Geom;;Vector3d.new 1,0,0).transform! e.transformation).length
                      scale_y = ((Geom;;Vector3d.new 0,1,0).transform! e.transformation).length
                      scale_z = ((Geom;;Vector3d.new 0,0,1).transform! e.transformation).length
                      bb = nil
                      if e.is_a? Sketchup;;Group
                        bb = Geom;;BoundingBox.new
                        e.entities.each {|en| bb.add(en.bounds) }
                      elsif e.is_a? Sketchup;;ComponentInstance
                        bb = e.definition.bounds
                      if bb
                        dims = [
                          width  = bb.width  * scale_x,
                          height = bb.height * scale_y,
                          depth  = bb.depth  * scale_z
                        UI.messagebox("Width;\t#{dims[0].to_l}\nHeight;\t#{dims[1].to_l}\nDepth;\t#{dims[2].to_l}")
                ### do menu
                if( not file_loaded?("jf_get_dimensions.rb") )
                  menu_name = "[jf] Get Dimensions"
                  UI.menu("Plugins").add_item(menu_name) { JF;;GetDimensions.get_dimensions }
                end#if
                file_loaded("jf_get_dimensions.rb")
                Robert
                  Like all of the cutlist and other extensions that output dimensions, those dimensions are the size of the bounding box. You need to correctly orient the axes so the bounding box aligns with the geometry.
                    robertWan
                    Yes, I know what the problem is.
                    I have removed the UI.messagebox window and display the results in VCB. Now it works more efficiently. You do not have to close the window after each measurement. Only with PAN or ORBIT the window is cleared.
                    Sketchup;;set_status_text(("#{dims.sort.reverse[0].to_l} x #{dims.sort.reverse[1].to_l} x #{dims.sort.reverse[2].to_l}"), SB_VCB_VALUE)
                    Robert
