    Lines thicken on enalrge in PDF
    2 Posts 2 Posters 198 Views 2 Watching
    • R
      roofup
      Using SU 2016 on windows 10 with Cute PDF writer driver.
      I have a Sketchup file imported into Layout.
      When I print a particular Layout file page to PDF, and I zoom in past 100% in Abode Reader, lines thicken.
      I have printed a PDF of the file direct from Sketchup, and get no issues when zooming the PDF then.
      In Layout I have deleted the inserted sketchup file, and reinserted it, but till get the same issue.
      Previously I had been fiddling with line weights within Layout, until I realised I should be doing it in Sketchup within the Profiles dialogue, have I set something here that is interfering.
      I have other pages in the layout file, with inserted SU files, which do not exhibit this behaviour.
      The difference though between these SU files is that the problem file, was orginally an imported PDF, imported into SU using the PDF Import Extension.
      Any idea why the interaction of Layout os causing this.
        How about sharing the LO file so we can see what you've got.
        The lines should appear thicker as you zoom in on the page in Adobe Reader.
