    Export Polygon Points to csv in correct order
    3 Posts 2 Posters 158 Views 2 Watching
      MLUY
      I have asked this question before but I guess its now somewhere on the bottom of the pile and I have not had a response yet πŸ˜• Before I abandon this idea I would like to give it one more try:
      I need to draw polygons (trace a scaled map) and export co-ordinates in the correct order to a csv.
      I found this great plugin from TIG (Export Vertices to CSV), which works fine, except it dumps the coordinates not by following the line segment order. I am trying to read the generated point file into a python script that redraws the polygon for me... but I get quite a mess this way...
      Thanks in advance!
      Michiel
        What is the "correct order"? How is that determined?
          MLUY
          Thanks very much Dave!!, I now realize that it is indeed a bit of a shady definition!
          I just meant that each polygon has a begin and an end-point and the "correct" order is getting the sequential line segments in that order. So for example for a polyline consisting of 3 line segments I would get 4 co-ordinates in order that makes up the polyline:
          x1,y1 start line segment a
          x2,y2 end line segment a, start line segment b
          x3,y3 end line segment b, start line segment c
          x4,y4 end line segment c
          I think this is the only way to rebuild a polyline if all you have are the co-ordinates.
          Regards
          Michiel
