    OpenCutList Grain Direction Issue
    3 Posts 3 Posters 820 Views 3 Watching
    • S
      skevorki
      Hello,
      I'm working on creating some dynamic components to help me speed up drawings and quote. This lead me to realize my grain direction isn't always what I want it to be when generating a cutting layout on OpenCutList.
      Example images: https://imgur.com/a/JIW7JF9
      Is there anything I can do to manipulate the cutlist or component to get the desired grain direction?
      • P
        pcmoor
        Match the X-axis to the grain (default), making one board with OCL attributes as well as DCs
        This simple board has a scaler so as to make unique on change, moreover it redefine the material scale (this can be used as a swatch and alternative code sorter)
        Saveas this to start the collection, building from the basic within the same file, if you build them separately it can lead to cross contamination.
        One creates a carcass by rotating, position and rename the boards(although they should automatically become unique, check that they are )
        I include a board example and carcass
        the board has one edge, typical of a basic part, from this one can use groups to create more complex boards (use solids, so can make whole when required)
        the example is set to definition, change it to none so as use the instance names, the generic parent! is used or latter swapped to, for DC reuse and any name changes
        Initially I use the instance method to define the members then switch to the Name attribute later using the dropdown option.
        The OCL is set to show DC Names
        OCL panels and carcass.skp
          In your image you show the grain direction running horizontally on the sides. Is that what you want? The more common method would be to have the grain running vertically. Not only does that tend to be more aesthetically pleasing but it's importand with solid wood. The way the grain is displayed on your model you would have gross grain joints between parts which will create issues with joinery. (If you ware using veneered termite excrement, that wouldn't be a big deal since there is no grain.
