    How to draw reinforced concrete using su
    2 Posts 2 Posters 242 Views 2 Watching
      swjtu817
      I want to draw a RC beam-column connection, How can i finish using su
      • gullfoG Offline
        gullfo
        what level of detail do you need? if it's just exterior - then extruding the beam and column shapes will do it. if you need the full rebar layout internally - that will be more complex. although there are a couple of concrete - rebar type plug-ins which would help.
        Glenn
        http://www.runnel.com
