    Copy group into a different parent
    2 Posts 2 Posters 3.1k Views 2 Watching
    • mariochaM
      mariocha
      With regards to parent, the API doc is pretty brief. Retrieve the name seems to be the only fonction.
      In ruby, Is there a way to copy a group in parent1 to parent2 ?
      %(#008000)[Mario C.
      • TIGT
        You have a reference to the entities of parent1.
        From which you can get the reference to the group.
        From that you can get it definition - group.definition
        You have a reference to parent2, and thus its entities
        Simply add the group's definition into that, retaining its transformation...
        Assuming parent2 is a definition...
        parent2.entities.add(group.definition, group.transformation)
        However, if parent2 is an instance use
        parent2.definition.entities.add(group.definition, group.transformation)
