    Rotate a solid to XYZ plane
    2 Posts 2 Posters 1.1k Views 2 Watching
    • M
      miker-gr
      Hello! I have a solid that i made it flat using the unfold tool. Now the flattened solid is 2D, but it's not aligned with any of the XYZ planes! I can use the rotate tool to change it, but is there a way to automatically make my 2d flattened solid parallel to XY or XZ or YZ plane?
      Thank you!
      • BoxB
        The answer to that really depends on what shape you started with and which specific unfold tool you used.
