    Shape Bender producing 2D results
    Scheduled Pinned Locked Moved Organic Modelling
    14 Posts 3 Posters 4.0k Views 3 Watching
      mannequiin
      Good day. This is my first time using Shape Bender. I have done all that I can but cannot seem to surpass this issue. Whenever Shape Blender is applied there are no errors...just flat, 2D results.
      After
      Before
        Post your skp in v 2017! πŸ˜‰
        • BoxB Offline
          Looks like you posted the same image twice.
            Else Shape Bender works fine like it must to do with a vertical flat group! πŸ˜„
            For avoid the big deformation of one part of the cross result
            Take the same length of the horizontal cross'length than the length's Arc! πŸ€“
            That is not the case here! πŸ’š
              Maybe True Bend by Thomthom will be more suitable ?
                mannequiin
                My apologies! Here is the true before ans after:
                Before
                After
                • BoxB Offline
                  You need to attach your model for us to give a full answer, but it looks like it is doing what you have told it to do.
                    mannequiin
                    Here in the SKP in 2017.
                    I was following a tutorial and modified the form a bit to suit my own interests. In the tutorial, the individual is able to achieve a more 3-dimensional form, if you will
                    SKP
                    Tutorial - before
                    Tutorial - After
                    • BoxB Offline
                      It's what I thought from your photo, the arc is on the wrong plan.
                        mannequiin
                        Thank you so much for your quick response!
                          mannequiin
                          Update: It worked beautifully!
                            About True Bend
                            You must make a component if you want a specific axis!
                              As said in my previous post you will have deformations! πŸ˜‰
                              (needing or not, depending of the result really wanted! πŸ˜„
                              Arc's length is 24,15 m
                              Line's length is 22, 94 m
                              So for a perfect result arc must be reduced! πŸ€“
                                As True Bend works only Object by the middle maybe you can use this little trick! πŸ˜‰
                                Open the component and add a little line! πŸ€“
