β οΈ Important | Please update Libfredo to v15.3a for bugfixes associated to SketchUp 2025 and below
Download
Shape Bender producing 2D results
Post your skp in v 2017!
Looks like you posted the same image twice.
You need to attach your model for us to give a full answer, but it looks like it is doing what you have told it to do.
Here in the SKP in 2017.
I was following a tutorial and modified the form a bit to suit my own interests. In the tutorial, the individual is able to achieve a more 3-dimensional form, if you will
Thank you so much for your quick response!
Update: It worked beautifully!
As said in my previous post you will have deformations!
(needing or not, depending of the result really wanted!Arc's length is 24,15 m
Line's length is 22, 94 mSo for a perfect result arc must be reduced!
