    Vanishing scenes
    2 Posts 1 Posters 3.0k Views 1 Watching
    • P
      pipingguy
      As I toggle between scenes, regardless of order, the screen turns blank just as the transition is complete and the scene is supposed to appear in its saved position. If I nudge the orbit tool, the scene appears - although out of alignment - obviously - which would throw off the established annotations in already created in the LO file. If I pan or zoom, nothing happens. If I double-click the scene tab it appears momentarily, then vanishes. Same if I double-click the scene name where it's listed in the Scenes inspector panel. Issue only occurs with some scenes and, for what it's worth, never happens with those set up in plan view. Scenes that properly appear share the same style with those which vanish. If I open the LO file created when everything worked fine, the problematic scenes appear - but in wireframe style. If I start a new LO file, the problematic scenes appear blank. My scenes in SU and LO worked fine for months. Now this. It must have something to do with recent version upgrade from '21 to '22.
      • P
        pipingguy
        I reached out to Trimble. They are working on it.
