    PROJECTGEOMETRY
    8 Posts 2 Posters 3.5k Views 2 Watching
      Scozzarella
      Is there a way in Sketchup or with an extension to repiclate the Projectgeometry command of AutoCAD?
      Projecting lines over solids and obtaining a profile around the solid.
        Scozzarella
        Schermata 2022-04-16 alle 11.22.45.pngSchermata 2022-04-16 alle 11.23.27.pngSchermata 2022-04-16 alle 11.24.11.pngSchermata 2022-04-16 alle 11.24.30.png
        • BoxB Offline
          If the example is all you need, then a simple stack of faces, grouped, and intersected with the other form, grouped, will give you the edges shown.
            Scozzarella
            Thank you but if I intersect then I loose my polars.
            • BoxB Offline
              I don't know what your Polars are, but I specifically mentioned both things being grouped. If you use intersect with two closed groups the edges are created outside the context of either group, therefore losing nothing.
                Scozzarella
                thank you very much. Could you please show me an example or a link video?
                • BoxB Offline
                  Something like this.
                  I'm not suggesting it is a solution to what you are asking for, simply a way to address your example.
                    Scozzarella
                    [attachment=0:1kfr868f]<!-- ia0 -->GIF 16-04-2022 8-51-53 PM.gif<!-- ia0 -->[/attachment:1kfr868f]
                    Thank you very very much. It' s kind of you.
                    Now I try.
