    Move multiple objects with red cross-marks
    1 Posts 1 Posters 1.3k Views 1 Watching
    • P
      pipingguy
      I just took notice of an improvement to the move command that must have been introduced in either '20 or '21. Prior to that, you could not move more than 1 object [group/component] at a time using any bounding box red cross-marks. The marks simply would not appear. However, in subsequent versions, if you select 2 or more objects, the marks do appear and if you grab one, you can move the entire set.
