    Replace identical components with one component (SOLVED)
    3 Posts 2 Posters 2.3k Views 2 Watching
    • S
      S1919
      I often have renamed components with the same geometry. For example when you use FredoScale every scaled component gets a unique name. (shelf#1 / shelf#2 .....)
      I would like to replace all these similar components with just one component (end hence the same name "shelf").
      This is very usefull for reports and lists that all identical compnnents have the same name.
      (for example open cut list)
      Anyone with an solution to achieve this?
      An extension?
      Thanks in advance,
      Searchie
      • BoxB
        Select all the ones you want to replace, then right click on the correct component in the browser and choose Replace selected.
        • S
          S1919
          SOLVED,
          Thanks a lot, now you tell me I heard once of this.....
          I also justed discovered you can use the extension SketchPlus
          Thanks !
