    2 separate onClick function
    4 Posts 2 Posters 4.4k Views 2 Watching
      MvanDijk
      In the attached skp file are 4 panels which are folding and sliding type.
      On 1 click , the first set will fold and the 2nd set follows by sliding.
      Now I need the 2nd set to fold as well once I click again.
      Tried to create a double click function by semicolon separation, but this results in the 2 foldings just at the same time instead of on each separate click.
      Is there any way to solve this.
      in short:
      1st click : open 1&2 + slide 3+4 (as in attachment)
      2nd click : open 3&4 right next to 1&2
      3rd click : close 3&4 again
      4th click : close 1&2 + slide 3&4
      Double folding.skp
      • P Offline
        pcmoor
        folding example
        if you nest the sections into one another, then change the driven attribute value to effect each part. Note axis change on part 3
        folding example.skp
          MvanDijk
          Thank you pcmoor,
          Thank you for taking the time to look into this.
          The end result is correct, all 4 panels next to each other in a vertical stand.
          However the action in between is suppose to be different.
          taking your example:
          at 1st click mat 1 and 2 should only fold , mat 3 and 4 must follow sliding (no fold).
          at 2nd click mat 3 and 4 should fold next to 1 and 2.
          So instead of 2 actions at 1 click (actually 4 in your case), I need 1 action at each different click.
          Then from there on I can reverse for closing again.
          • P Offline
            pcmoor
            Bed with two folds that have independent onclicks, with a test to check position of the first.
            the move is tied to the second fold.
            It may be enough or give you some ideas
            You could consider a Set function for conditions, required if are placing the animate in the parent
            folding example.skp
