    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    Tiny House Attempt
    50 Posts 11 Posters 26.4k Views 11 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Hi Guys,
      I'm resurrecting this post as I'm currently designing a Tiny House for a client/friend.
      The regulations for in-situ Tiny Houses here in Ireland are far more strict than they are in the UK. In the UK it seems a Tiny House is classified as a caravan but here in Ireland it falls under the domestic structure category with all the building regs that entails. I suppose I could put it on wheels!
      Still, my initial attempt is, I feel, more in keeping with the Tiny House ethos and I'll push as far as I can until I reach a brick wall. It's the Fire Regs that are sticky but from past experience I have learned that if its possible to meet or possibly surpass the regs by other means it might be a flier.
      The areas of contention are the sleeping loft head room and the short (overall) run of the stairs with its single foot area per step/thread. I've used this type of stair design before for loft storage entry. Once the user gets used to them they work fine.
      The HWB/Shower/WC Pod construction should be fun but the upside is that one can soak their feet while on the WC ๐Ÿ˜‰
      I'm attaching a short video of the initial design, warts and all for comments, here. https://youtu.be/Nh1LWAkVwEI
      Mike
        Hey Mike please check your Youtube settings. It says your video is private
          Mike Lucey
          Hi Liam,
          I changed the YouTube video to Public. Hope it works.
          Mike
          • boofredlayB Offline
            boofredlay
            Nice presentation and design Mike.
            • Joe WoodJ Offline
              Joe Wood
              That's a nice presentation MIke!
              give any thought about ridge and soffit vents?
              Joe Wood
              woodsshop.com/
                Mike Lucey
                Thanks for showing your interest guys, much appreciated.
                Joe, good point. However I'm now looking at the possibility of a mono truss type construction. This would serve two purposes, elimination of fascia/soffite and allow for a single material for roof and walls. Not sure, yet about which sheeting material to use yet, ideally it would need to be able to take a 45 degree bend. Timber ventilation would then be from the base (wall) to the ridge with vents positioned there.
                  Mike Lucey
                  .... still playing with the tiny house design. I've eliminated the Velux windows also the eaves on the current design iteration and am looking at corrugated bitumen sheeting. I've sourced a manufacturer that produces sheets and accessories from 100% recycled materials, so that's a plus.
                    A very interesting project, not easy are they? I found flat or very slightly sloping roof's work best for volume/footprint usage.
                    The alternate one foot steps have been used in boats and loft extensions for a long while but they would take some getting used to. Step off with the left foot and it's a LONG first step.
                    Solar or sun tubes are unlikely for this type of design which is a nuisance, they can liberate a lot of natural light and improve the feel of a home. A cupola type of unit perhaps?
                      Mike Lucey
                      Yes Mike, I'm finding the project very interesting.
                      The stairs is tricky to get right. My proposed ground floor to bottom of floor joists will be 2.1m (approx 7'0"). I will expose the floor joists in order to give the impression of more height. The rise per step will be approx 230mm a shade over the normally allowed maximum in standard dwellings (225mm).
                      I've used this type of stairs on a few attic conversions in the past and once the occupier gets used to them they work fine. I have included two hand rails which wrap around the 1st floor partition. These should help to make the stairs safer to use.
                        Mike Lucey
                        Meeting the kitchenette requirements has been a little tricky but I'm nearly there. I have to yet change the single bowl sink to a bowl/drainer and its done. Compact Minumum Kitchenette.gif
                          Nice work! must be a fun project Desigfning for yourself. One thing is those steps will not pass building code I would wager ๐Ÿ˜‰
                          • Joe WoodJ Offline
                            Joe Wood
                            these stairs might meet code better Mike, as they have closed risers. I saved these from somewhere way back during the @Last days.
                            FF_Model_ID2396_1_spacesaverstair_gratis.skp
                            Joe Wood
                            woodsshop.com/
                              Hi Joe, those stairs wont work. Risers and tread need to be consistant as if you do not watch your feet Like in the dark you not have a predictable rise, if you have a bias to the left or right of the staircase or transitioning between the two...............thump crash
                                In the UK 'space-saver' stairs [alternating-treads] are allowed if accessing limited upper-floor space, and they meet a set of rules... e.g.
                                https://www.loftcentre.co.uk/loft-stairs-spirals/space-saving-stairs
                                In Ireland there are similar, if different, possibilities...
                                https://connollystairs.ie/product/space-saver-attic-stairs-ireland/
                                  Thanks for clarifying TIG, about 8 years ago part of my job was building compliance in Australia. So it makes sense for things to have changed with higher density living initiatives including shipping containers. Australia may have moved on the building codes, we often move inline with the UK ๐Ÿ˜ณ
                                    Thinking a bit about this, is there a need/use for a thread about these projects? Something where people can exchange idea's and ask questions? Example, just what would be considered essential for a small home to be habitable without the resident going completely round the bend and, I don't know, go into politics?
                                    Something I was thinking for Mr Mayor's project is a roof that can be pushed up like an awning, making an opening for summer. Possibly have a screen for the biters.
                                      Mike Lucey
                                      Hi Mike,
                                      I also think a thread for these kind of projects would work well. Possibly a sub forum for design projects in general where members here that are in various fields of design could show projects to the general community and at the same time benefit from concrete feedback.
                                      Such a sub forum might also transition into a place that would allow the designers to sell the designs via SketchUcation thus generating income from their work.
                                      I take your points regarding a cabrio roof and screen for 'biters' but here is Ireland we really don't get a lot sun and we have very few 'biters'. I have modified the design further to include a fixed cantilevered canopy. I'm currently finalising a short presentation movie and will load a link to same shortly for comment.
                                      Mike
                                        Mike Lucey
                                        I've simplified and finished the design for the Tiny House and am now putting the presentation movie together. I should have it finished a in couple of days and will post here.
                                        The key to the simplification was the use of the Friheten Sofa Bed which is available at IKEA.
                                        I am attaching shots showing how this sofa bed transforms.
                                          I am convinced that ratio of depth to width is the key to real habitability in these small properties. 2 to 1 seems to be a sweet spot.
                                          • daleD Offline
                                            dale
                                            These aren't quite as tiny as yours Mike, but the idea of pocket neighbourhoods is worth a look. He also includes lot of fine innovations.
                                            Pocket Neighborhoods - Ross Chapin Architects
                                            Pocket Neighborhood Projects
                                            Ross Chapin Architects (rosschapin.com)
                                            • 3 / 3
