    Broken line segments still generates a surface area?
    7 Posts 2 Posters 4.8k Views 2 Watching
      MLUY
      Hello There !,
      I am trying to extrude attached surface area into a solid to do some volume calculations (merge / subtract operations) But I am getting a lot of errors on the edges of my extruded shape. I am pretty sure it has to do with the fact that the border edges are broken into segments whilst there are no triangulation lines. How can Sketchup still generate a surface area and how do I get rid of this (without doing it manually?) and generate a proper surface to extrude?
      Michiel
      • P Offline
        Better if you can send your skp (save as version 6) for a more large audience! πŸ€“
          MLUY
          @mluy said:
          Hello There !,
          Michiel
          SurfaceArea.skp
            MLUY
            @mluy said:
            Hello There !,
            Michiel
            SurfaceArea_ver6.skp
              MLUY
              Thanks, I just uploaded the file.
              • P Offline
                You can resize your object by 1000
                then use CleanUp by Thomthom it finds many problems and repears
                Then Joint PushPull by Fredo for give a thickness
                Then solid Solver by Tig
                But despit of that seems there are always problems, too little surfaces, maybe intersect faces etc...
                where does this object come from? An unfolding one ?...
                  MLUY
                  Thanks Piloe, its the result of an intersection with two solids from a topographic survey but its a complete mess. I just spend 3 hours to do it manually and finally managed to get a clean solid (joint push pull V) I guess there is no easy way when you get a shape like this
