    Figure of eight with a twist
    7 Posts 3 Posters 4.3k Views 3 Watching
    • chrisglasierC
      chrisglasier
      On the ear'ol again I am afraid.
      I am looking for a model of a figure of eight with the top loop 90 degrees to the bottom. It is to strap two 25mm pipes that cross each other together.
      The straps should be at 45 degs to the pipes
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
      • Jean LemireJ
        Jean Lemire
        Hi Chris, hi folks.
        See this SU file for ideas.
        Pipe support choices.skp
        • chrisglasierC
          chrisglasier
          @jean lemire said:
          Hi Chris, hi folks.
          Thanks Jean,
          I am trying to show how the finished joint will look ... there are many ... a neater version of this type of thing.
          The pipe runs are on a roof that is on the shore of the Indian Ocean, so I am proposing using PVC pipes for the gantries and some kind of PE banding to bind the existing PVC water pipes to replace this mess:
          So I need to present the final new look to compare.
          The installer creates a band like you have modelled but with a waist both to tighten and tie off the banding (hence figure of eight).
          I tried but found that too much for me ... that is why I am back here!
          Cheers
          • Jean LemireJ
            Jean Lemire
            Hi Chris, hi folks.
            What do you intend to use for banding ?
            Can you post a picture or is it like shown with dry vegetal fibres (bamboo ?).
            • chrisglasierC
              chrisglasier
              @jean lemire said:
              Hi Chris, hi folks.
              This is a better picture
              It is very strong; sold in 600mm lengths. Not sure I can get in Sri Lanka, but other material will look similar.
              • B
                Builder54
                Possibly a rivet joining to 2 clamps together.
                "Don't be afraid of working hard. There are No shortcuts to mastering something."
                Robh Ruppel
                • chrisglasierC
                  chrisglasier
                  Thanks for your input but my problem is really how to model a path that binds one tube to another at right angles when extruded as a tape or wire. Actually, I am thinking of trying plastic coated electrical wire as a durable and readily available material. It needs to have a waist to really tighten the binding; the salt-laden tropical winds can be really vicious.
