    360 animation with Circular Camera Extension
    2 Posts 2 Posters 4.9k Views 2 Watching
    • webbubblerW
      webbubbler
      Hello,
      I've been a user for a long time of Circular Camera extention from DeLuminae.
      The latest version allows you to generate scenes (in Sketchup) from a 360 animation, and it's a major upgrade. So I created this video to explain how to.
      You may create 360 animation, generate the images with Sketchup, and assemble the result in a video file with a graphic software (I use PhotoShop, but many other options do work as well) or generate the movie directly from Sketchup.
      You may also generate all scenes of the 360 animation in Sketchup, render each of this scenes with any rendering Software (I use Vray, but it should work in others render Soft)
      • The ability to generate scenes is just great
      • Works with Sketchup 2016/2011, despite it is not specified
      • One cool device is to be able to select the starting view and the center of the animation
      • It does work very well for inside or outside projects, or even object such as the suitcase in the video
      • The only downside for rendering is the speed of your computer, as always
      • Very simple, interesting options, and it is free 😉
      Available from the Extention WareHouse or directly on their website:
      https://deluminaelab.com/company/en/camera_circle.html
      • B
        BallBearing
        Very nice! It was easy to make eight compass point views, scenes: Images folder, set center point, set start view. Edit config: Duration 8s, FPS 1.
        SketchUp, 3D printing stuff and more:
        http://www.youtube.com/user/CinemaTablet
