    Is there a Match Current Tag or Match Properties Plugin?
    5 Posts 2 Posters 2.5k Views 2 Watching
    • Gus RG Offline
      Gus R
      I'm curious if there is a match current tag (layer in older versions) or match properties plugin that doesn't require menu boxes, pull down menus, etc, and much like you have in Autocad. According to what I searched the answer is no but I thought I'd ask. Thanks.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • pbacotP Offline
        Like TT "selection toys"? You DO have to pull down the contextual menu.
        What properties are there in SketchUp? Object type, material, layer. At least these tools cover it. Or do you mean it has to be sort of a magic wane tool, just click on something and it'll select whatever has all matching properties?
        • Gus RG Offline
          Gus R
          Thanks.
          I was looking for something like Match Properties (which like a magic wand tool) and/or something similar to Layer Express.
          With Match Properties I click on one item and then I click on the other item I want to change and it applies all the properties from the first selection. I use if for linetypes, colors, layers, text, etc.
          While not look for everything Layer Express could do here's what I have in my CAD set-up.
          • pbacotP Offline
            Oh, I thought you meant a "Selection" tool.
            So, what properties?
            Material : The material tool (paint bucket) has this built in. The only other property that I think you would wish to copy is Tag/Layer.
            • Gus RG Offline
              Gus R
              Just a two click Tag/Layer plugin.
              I'll just make sure I draw on the appropriate tag/layer from now on.
