    Call for Plugin image/anotation link to SU Model
    10 Posts 4 Posters 3.3k Views 4 Watching
      atelierpaar
      Hello,
      I need a Plugin that links images and annotations to a SU Model.
      The idea is, to place markers in an exact Model location in order to link and open images in a viewer.
      There should be different "custom-designed" markers to be assigned to different categories of images.
      The functionality should be transported from SU to LO.
      Question: is there something similar available, or is somebody interested to design this tool?
      Thanks for your comments and hinds
      Uli
      • BoxB Offline
        Have a look at Go Su
        https://sketchucation.com/pluginstore?pln=RND_GOSU
          Didier Bur
          Or this: https://extensions.sketchup.com/extension/2cdafc72-6724-4bad-8afe-b24b269e041c/links-manager
          DB
            juju
            Aaah, yes, what would be great is if these referenced documents / notes / whatever could be invoked with the text labels function in both SketchUp and LayOut!
              atelierpaar
              Hello,
              thanks for your comments.
              I will check the functions of the plugins an let you know how far i got
              Uli
                atelierpaar
                Okay
                i checked Gosu and link manager
                Both tools seem to be a good start of
                Gosu
                works fine inside SU
                pro___it will open the text/image file right form sketchup
                con___a Description can not be added to the linked Object
                _______functionallity will not be transported do LO
                link manager
                pro___a Description can be added to each linked Object
                ______the linked file will open in sketchup
                con____functionality will not be transported do LO
                unfortunately I have no idea about designing a plugin
                Somebody interessed to help
                thanks
                Uli
                  Didier Bur
                  con___the linked file will not open automatically in sketchup
                  PDF help says:
                  DB
                    atelierpaar
                    thanks Didier Bur,
                    I found that one out a little later.
                    Do you see chances to develop the plugin further
                    greetings
                    Uli
                      Didier Bur
                      @atelierpaar
                      What features would you like me to develop or enhance ?
                      Regards,
                      DB
                        atelierpaar
                        Hello Didier Bur,
                        I will try to sketch what I have in mind.
                        Do you have a mailbox to send you a rough idea for a tool description and some sketches ??
                        Greetings,
                        Uli
