Call for Plugin image/anotation link to SU Model
Hello,
I need a Plugin that links images and annotations to a SU Model.
The idea is, to place markers in an exact Model location in order to link and open images in a viewer.There should be different "custom-designed" markers to be assigned to different categories of images.
The functionality should be transported from SU to LO.Question: is there something similar available, or is somebody interested to design this tool?
Thanks for your comments and hinds
Uli
Have a look at Go Su
https://sketchucation.com/pluginstore?pln=RND_GOSU -
Aaah, yes, what would be great is if these referenced documents / notes / whatever could be invoked with the text labels function in both SketchUp and LayOut!
Hello,
thanks for your comments.
I will check the functions of the plugins an let you know how far i got
Uli -
Okay
i checked Gosu and link manager
Both tools seem to be a good start ofGosu
works fine inside SUpro___it will open the text/image file right form sketchup
con___a Description can not be added to the linked Object
_______functionallity will not be transported do LOlink manager
works fine inside SUpro___a Description can be added to each linked Object
______the linked file will open in sketchupcon____functionality will not be transported do LO
unfortunately I have no idea about designing a plugin
Somebody interessed to helpthanks
Uli -
thanks Didier Bur,
I found that one out a little later.
Do you see chances to develop the plugin further
greetings
Uli -
What features would you like me to develop or enhance ?
Regards, -
Hello Didier Bur,
I will try to sketch what I have in mind.
Do you have a mailbox to send you a rough idea for a tool description and some sketches ??Greetings,
Uli
