    .shp file directly import into sketchup?
    8 Posts 5 Posters 8.3k Views 5 Watching
    • MatteM Offline
      Matte
      Hi all, I heard someone made a plugin a while back that would allow you to import a shape file directly into sketchup? Does anyone know anything about this plugin?
      Thanks, Mattee
      • P Offline
        pinoy
        Have you try universal importer plugin?
          alpro
          https://forums.sketchup.com/t/importing-shapefiles-shp-to-sketchup-skp/59032
          • jujuJ Offline
            juju
            The links to the extension are all dead. 😞
              alpro
              Try this https://sites.google.com/site/spirixcode/code
              • G Offline
                Glenn at home
                If you don't get an answer I have AutoCAD Map and can insert a .shp file and export to a dxf/dwg for you.
                • MatteM Offline
                  Matte
                  Thanks Glenn, I just downloaded the Spirix shapefile importer, I'll give it a go. If I have problems, I'll contact you if that is ok?
                  Thanks, Matte
                  • MatteM Offline
                    Matte
                    Thanks Glenn, that did the trick!
