    .shp file directly import into sketchup?
    8 Posts 5 Posters 7.9k Views 5 Watching
    • MatteM Offline
      Matte
      Hi all, I heard someone made a plugin a while back that would allow you to import a shape file directly into sketchup? Does anyone know anything about this plugin?
      Thanks, Mattee
        pinoy
        Have you try universal importer plugin?
          alpro
          Importing Shapefiles (shp) to SketchUp (skp)
          Hey Everyone, I’m working on a neighborhood master plan using SketchUp Pro (2018), Google Earth, Google My Maps, QGIS, the City of Detroit Open Data Portal, Loveland Technologies, etc. I’ve spent like 2 days now trying…
          SketchUp Community (forums.sketchup.com)
          • jujuJ Offline
            juju
            The links to the extension are all dead. šŸ˜ž
              alpro
              Try this https://sites.google.com/site/spirixcode/code
                Glenn at home
                If you don't get an answer I have AutoCAD Map and can insert a .shp file and export to a dxf/dwg for you.
                • MatteM Offline
                  Matte
                  Thanks Glenn, I just downloaded the Spirix shapefile importer, I'll give it a go. If I have problems, I'll contact you if that is ok?
                  Thanks, Matte
                  • MatteM Offline
                    Matte
                    Thanks Glenn, that did the trick!
                    With your input, this post could be even better šŸ’—
