    Remove custom material
    1 Posts 1 Posters 1.6k Views 1 Watching
    • M
      MR H 91
      Hello
      I've searched the forum for an answer, and have found a couple of posts that are similar to my request, but there wasn't a solution to my problem.
      I'm fairly new to Sketchup, I have SU Make 2017. I was messing around with custom colours and textures the other day, and I stupidly made an OSB wood texture using a PNG image that I designed in Illustrator. The file is HUGE, and it slows my MacBook down even when opening the "Wood" folder in the materials list (see thumbnail image below).
      When I right click and delete the texture from the "Wood" library, it deletes, as expected. However, when I quit Sketchup and re-open it, the texture is there again!
      https://i.ibb.co/tXmLKt5/Screenshot-2021-01-10-at-00-01-11.png
      I have tried time and time again to find the folder on my MacBook in which the image is stored. There is nothing showing in SketchUp 2017>Materials (other than some .skm textures downloaded from sketchUcation) see below.
      https://i.ibb.co/4Y7tbgN/Screenshot-2021-01-10-at-00-13-20.png
      Essentially, I'm asking where am I able to find this image now stored in Sketchup, and how do I permanently delete it?
      Thanks in advance.
