    Disrupted faces
    2 Posts 2 Posters 1.1k Views 2 Watching
      matsuo_lano
      I've subtracted 3 rounded solid shapes from a cylinder, only to find out the faces were 'disrupted'. Is there any way to fix this, or should I try something entirely else? Maybe some plugin I can use?
      You try to rearrange me 'till I'm sane
        I believe the only thing you can do is reduced these disruption by increase the number of segments of all rounded parts: cylinder, cuting forms etc...
        But as SketchUp is not a Nurbs prog you will have always little default of continuity in Boolean operations when they are not straight lines! πŸ˜„
        Else best plugin for Boolean operations is BoolTools 2 ! (better than the native function)
        (for SU MAKE or Pro)
