    Delete and update add_note don't work
    6 Posts 4 Posters 6.3k Views 4 Watching
      mr_Creator
      Hello,
      I create note:
      @note = Sketchup.active_model.add_note 'Note', 0.8, 0.9
      But I cannot delete and change the note. Help please, I used different methods, but none helped.
        dezmo
        You may realised that is creating Sketchup::Text https://ruby.sketchup.com/Sketchup/Text.html
        To change:
        @note.set_text "This is another note"
        Most probably to see changes, the view need to redraw.
        Sketchup.active_model.active_view.invalidate
        do delete:
        @note.erase!
        Man can do everything. Only a matter of time and money.
          mr_Creator
          To change:
          do delete:
          @note.erase!
          When i use:
          then I get this (check image)
          http://dl3.joxi.net/drive/2020/08/22/0001/3576/101880/80/ddb0945bc7.jpg
          the text is superimposed on each other. Sketchup 2020
            dezmo
            @mr_creator said:
            When i use:
            You didn't say what you didbefore.
            I guess you actually did something like this:
            If you can tell me what your goal is at all, I might be better able to suggest something... πŸ˜‰
              The bare bones code is:
              note=Sketchup.active_model.add_note("The initial note", 0.8, 0.9)
              ### where 'note' is a reference to that newly made text-entity
              ### refreshes the view
              later on you can use
              note.text="This is the changed note"
              The @note would only apply if you are reusing variables between methods etc.
              Also the set_text(...) method operates outside of the undo-stack, whereas the text= works within it.
              Also, please parenthesize your arguments...
              To erase the note use note.erase!
              • Dan RathbunD Offline
                Dan Rathbun
                Just tested Sketchup::Text#set_text on SU2020 and it (as Dezmo says) does not display the change until the view is redrawn. So Sketchup.active_model.active_view.invalidate is necessary to see the change.
                I'll open a documentation issue for this "quirk".
                I'm not here much anymore.
