    Bin_LibFredo6.so
    extensions
    1 Posts 1 Posters 4.1k Views 1 Watching
    • zooenZ
      zooen
      After updating Fredolib (today, latest version) the file mentioned above is systematically blocked by my antivirus and no plugin is loaded.
      The start of the error report
      Erreur de chargement du fichier Fredo6_!LibFredo6.rb
      Error: #<LoadError: 5: Acc\xE8s refus\xE9. - C:/Users/fosse/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU20/bin_LibFredo6.so>
      C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
      c:/users/xxxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:622:in load_binary' c:/users/xxxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:257:in startup'
      C:/Users/xxxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:61:in process' C:/Users/xxxxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in module:LibFredo6_Loader'
      RE,
      Bon en redémarrant l'ordi tout fonctionne. Donc pas d'explication pour moi. Souvent le fait de redémarrer l'ordi corrige les dysfonctionnements lors de mises à jour de logiciels, mais je n'y avais pas pensé.
      Bonne fin de journée, Zooen
