    Please Help! Round Corner Not Working in SketchUp 2015
    5 Posts 3 Posters 3.1k Views 3 Watching
    • S
      SketchUcation Kid
      please help!
      I installed RoundCorner_v3.3a.rbz in my SketchUp 2015 but nothing happens. It doesn't appear anyware. I also can't install LibFredo6, which is required to run Round Corner. I would life to know how to get earlier versions of LibFredo6.
      thanks in advance.
        This is not a bug so I moved your thread.
        You need to installed the archived older version of LibFredo6. Here's the link: https://sketchucation.com/pluginstore?pln=PRIOR_SU2017_LibFredo6
        Also install the older archived version of Round Corner. https://sketchucation.com/pluginstore?pln=PRIOR_SU2017_RoundCorner
        • S
          SketchUcation Kid
          I've already installed both versions. it did not work anyway. I'm looking for Prior2016 versions. how can I get it?
          thanks for the prompt reply.
            On the link of Dave it's writed prior 2017 so it's prior also 2016! πŸ˜‰
            So fine for the 2015 Make! πŸ˜„
            My files linked "C:\Users\user\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins..."
            RCorner.zip
            • S
              SketchUcation Kid
              yesterday night I could download and test RoundCorner_v3.1b and it finally worked. I'm so glad! I also could download LibFredo6_v8.0c and it worked like a charm.
              I saved the RoundCorner version that you have put available anyway but also will attach my RoundCorner version. LibFredo is too big to attach.
              I thank you all for the help.
              [mod=:13z9pkfv]Extension file removed. Please don't add copies of extensions from other authors. It results in confusion for others. In this case Fredo6's Round Corner for older versions of SketchUp (pre-2017) is available here.[/mod:13z9pkfv]
