    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 182.3k Views 40 Watching
      rv1974
      @fredo6 said:
      The issue was signaled during the Beta testing but was not fixed in the release (among other issues and bugs).
      I'd love to see those reports, was it opened discussion?
        rv1974
        Well I tested the latest FredoSpline in v2023 unfortunately almost everything is broken (in context): Edit, Swap etc. This is the worst SU release ever since v2 πŸ˜• . Tons of crashes on start and during all sorts of procedures. Will have to get back to v2022 till they'd sort it out
          I'm not having any crashes of SU2023 at all. It's been very stable for me.
          • jenujacobJ Offline
            jenujacob
            Hi Fredo..
            i just updated the libfredo and fredo spline now and since then i am unable to open the quick launchers of Fredo spline, joint push pull, fredo scale and the check fredo6 plugins for update menu. attaching the error in the rubby console below.
            Error; #<NoMethodError; undefined method `wdlg_from_key' for Traductor;;Wdlg;Class>
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe;37;in `check_instance_displayed'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe;42;in `invoke'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;213;in `invoke_quick_launcher'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;268;in `launch'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;250;in `action__mapping'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;120;in `launch_action'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;133;in `block in startup'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1469;in `command_invoke'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1449;in `block (2 levels) in build_config_commands'
            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
              rv1974
              they published a new build - Swap Curves and Sandbox's Drape (not yours, I know) still don't work in context.
              Will have to skip this version too πŸ˜„
                JHJ001
                hello. I'm a Korean user who uses Fredo's products usefully.
                A little while ago, I purchased a license for 'fredo spline' and pressed the 'Download' button,
                but the result is a white screen with only the text below.
                /pluginrepo/rbz/
                /var/www/html/pluginrepo/rbz/FredoSpline.rbz
                File does not exist. Make sure you specified correct file name.
                If anybody know a solution, please send 'e-mail' to help. Thank you.
                email address β–Άjhjncorp@naver.com
                • H Offline
                  HaroenMartens
                  Question
                  I paid for a license, however my plugin keeps telling me it doesnt work due to the fact that i have not the latest version of it. I keep on installing v 2.5 over and over but it keeps sending me the same message. It used to work perfectly in an older version. I cannot seem to fix the issue.
                  Any thoughts or people experiencing the same issue?
                    Do you have the current version of LibFredo6 installed? Also the current version of the Sketchucation ExtensionStore? Both of those are required. Share a screen shot of the error message you're getting.
                    Are you still using SketchUp 2015 Pro as indicated in your forum profile?
                      rv1974
                      Fredo, is it possible to implement a general weight setting in "convert curves" and "edit curves" commands please?
                      I get used to create all sorts of fredo curves out of faces or chains of straight edges and really miss this general setting. It also counter-effective to change the weight one-by-one in edit
                      • fredo6F Offline
                        fredo6
                        I get used to create all sorts of splines out of faces of chains of straight edges and really miss this general option. It also counter-effective to change the weight one-by-one in edit
                        I think you can select several control points and chenge the weight in one action.
                          rv1974
                          Thats news to me. so how do I change the weight globally?
                            rv1974
                            Also, in case of polycorner arc editing.. I really miss ability to choose (with crossing window and\or by single picks) several vertices and change their radius at once. So again mass editing is really welcomed.
                              rv1974
                              my humble request: window selection - most obvious and basic functionality. currently the process of vertex selection is not bearable.
                              Yet another idea: in edit, ability to assign different types of vertices in given spline(s) : arc, bezier, simple corner.
                              • fredo6F Offline
                                fredo6
                                NEW RELEASE: FredoSpline v2.6a - 01 Apr 24
                                Requirements
                                • LibFredo6: v14.3b
                                • Sketchucation PluginStore: v4.4.0
                                FredoSpline 2.6a is a maintenance release for:
                                • Future compatibility
                                Home Page of FredoSpline for information and Download.
                                Main post of this FredoSpline thread.
                                • zivotinjaZ Offline
                                  zivotinja
                                  I own a bundle bu I do not have bezier curves. HOw can I add this plugin to the bundle?
                                  Thank you
                                  Best,
                                  Nenad
                                    rv1974
                                    Maybe I missed it, but Its surprising nobody reports this faulty behavior
                                    When changing radius with mouse wheel at some stage the plugin jumps to radius 0 and its impossible to change it anymore:
                                    Also, any editing (adding, deleting, moving) in majority of situations would delete existing faces:
                                    How about editing multiple curve at once:
                                    P.S. Fredo, It was requested in the past and its not implemented, but hope dies last: Is it possible to preserve plane constrains after editing is finished please? Thanks
                                    fredo6F 1 Reply Last reply Reply Quote 0
                                    • fredo6F Offline
                                      fredo6 @rv1974
                                      @rv1974
                                      For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner. This allows to only round long edges when you do it globally.
                                      Deletion of faces happens when you change the number of vertices. It is somehow difficult to maintain the face.
                                      It seems to me that if you created the curve with a specified plane, the edition of vertices will be along the plane.
                                      R 1 Reply Last reply Reply Quote 0
                                        rv1974 @fredo6
                                        This post is deleted!
                                          rv1974
                                          @fredo6
                                          For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner..
                                          OK, but it should not break scrolling.
                                          In many situations a banal vertex moving deletes face as well .
                                          Unfortunately - no , it can easily run away from the plane. Also, if there are objects not laying on this plane - SU easily snaps to them.
                                          is it possible to implement scrolling\nudging based on exact user defined values ?
                                          currently there are no exact values on radius\tension changing. This feature would be extremely useful in other plugins where scrolling\nudging being used - PaintThru, Axiz etc.
                                          Thank you for attention
                                            rv1974
                                            • 6
                                            • 7
                                            • 8
                                            • 7 / 8
