    Killing AutoCAD Using SketchUp?
    1 Posts 1 Posters 5.7k Views 1 Watching
    • fionmacoolF
      fionmacool
      Now I don't want to besmirch the fine software known as AutoCAD. It has underpinned much of the progress in architecture and construction these past forty years.
      http://chrisglass.com/album/wp-content/uploads/2013/03/0311-apt-990x659.jpg
      Typical example of the kind of subtle masterpieces that AutoCAD is renowned for. (Image: chrisglass.com)
      For small drawings which incorporate lines, curves, dimensions and text there's no better solution out there. But if you want to draw anything bigger than a steel joint or a shed (Things which fit nicely into a single screen.) then it may be advisable to look for another solution.
      Using SketchUp to produce Plans Sections and Elevations has the following advantages:
      • Everything fits on a single screen.
      • There's no such thing as incorrect or non-aligned drawings (unless there's obviously something wrong with your model.)
      • Changes only have to be made once, not 4 - 8 times.
      • Contains textures.
      • Shadows.
      • Video Output.
      • Rapid editing.
      • LayOut now has a 2D drawing "Scaled Drawings" built-in application.
      https://viewsion.ie/wp-content/uploads/2020/02/LayOut-SketchUp.com-Blog36.57-copy-2.png
      • There are countless add-ons including:
      • Quantity take-offs.
      • Construction sequencing linked to Synchro.
      • Energy Analysis Tools.
      I almost forgot:
      • SketchUp Pro is cheaper than AutoCAD.
      For those unreasonable mavericks out there, my new book "Construction Documents Using SketchUp Pro 2020" is available on SketchUcation: https://sketchucation.com/shop/books/intermediate/227-sketchup-for-construction-documentation-2020
      Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
