    MS Physics help
    extensions
    6 Posts 4 Posters 4.1k Views 4 Watching
    • soloS Offline
      solo
      I need help figuring something out, see image below, the poles are holding up the balls, I want to show what happens when certain poles are removed, how can I do that?
      Currently I have poles as static.
      http://www.solos-art.com
        Normally just move the poles one by one out off the tube! πŸ˜„
        • soloS Offline
          solo
          You think I never tried that? πŸ˜‰
          It is not selectable as static, and if not static it just falls
          • gillesG Offline
            gilles
            Don't made them static, put a slide joint along their axis on them so you can move them and release the balls.
              It was implied! πŸ˜‰
              Funny the MS Physics!
              https://i.postimg.cc/63wVvk68/GIF_door1.gif
              • cottyC Offline
                cotty
                If they fall, the glass with the holes is probably incorrect? You can use Fredos convexify (part of FredoTools) to subdivide it to convex shapes ...
                my SketchUp gallery
