    [Request] CPoints at fixed intervals with line tool.
    2 Posts 2 Posters 1.3k Views 2 Watching
      LevJoz
      Hi everyone!
      Would it be possible to make a plugin that's similar to the line tool but in addition adds CPoints at an interval that is determined by the user.
      This would act as a virtual "framing layout stick" to quickly mark studs by pulling a line that leaves the CPoints.
      Thank you!
        You could do this sort of thing with Profile Builder 3 or you could use Divide CPoint which is available in the Plugin Store.
        I'd just make a stud component and copy it at the desired interval. That would save some time and effort. That also doesn't require an extension although the ninja thing would be to use the stud as a component in an assembly and use Profile Builder 3 to place them.
