    Set_attribute problem
    3 Posts 2 Posters 6.3k Views 2 Watching
    • PixeroP Offline
      Pixero
      I'm getting an attribute from a component this way:
      @myid = e.definition.get_attribute("A", "Id")
      If I do a:
      puts @myid
      I get the correct value.
      Something like this: 0481e69d-cbc0-4e4c-2c32-e2d2f7932bdf
      And setting it this way:
      e.definition.set_attribute("A", "Id", @myid)
      or
      e.definition.set_attribute("A", "Id", @myid.to_s)
      But all I get is nil.
      What am I doing wrong?
        If you use this code in your script, then what do you see in the Ruby Console when it runs ?
        puts"{@myid}"; e.definition.set_attribute("A", "Id", @myid)
        Remember that @myid will probably not be accessible in the Console, as I suspect that it's being set within your own method ??
        • PixeroP Offline
          Pixero
          ~~Then I get:
          {@myid}
          I'm doing it inside a:
          sel.each {|e|
            puts"{@myid}";
          Edit:
          Doh! 😳 It was all a small typo with a D instead of a d.
          Works as it should now.
