    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Fredo6 BezierSpline_v2.1a Having Trouble
    7 Posts 2 Posters 2.5k Views 2 Watching
      Bluewater77
      Hello, I installed this and having some issues. I have SKP 2018 Pro. Maybe I am not using properly as I am not advanced user and Bezier spline novice.
      When I choose Polyline with Arc Corners and start to draw. Two things... 1st is that no menu window for offset pops up. 2nd is that when I start to draw, it disappears when trying to set points. So I can't see the polyline that I am trying to draw? Advice appreciated!
      • fredo6F Offline
        fredo6
        Could you open the Ruby Console and see if there are errors showing.
          Bluewater77
          Thanks Fredo6. Nothing shows in Ruby Console. I tried drawing a Polyline with Arc Corners and it dissapears after selecting point #1. I click for point 2 & 3 (eventhough I can't see and choose to end and close tool) Then there is nothing on my screen?? And Ruby Console is blank
          • fredo6F Offline
            fredo6
            Do you get the same problem with other curves, like Bezier, Cubic Spline, Polyline, ....?
              Bluewater77
              Sorry Fredo6 for late response. Not getting reply notifications... It happens i.e. after 1st click, everything disappears.
              on all except for classic bezier, polyline, catmull, courbette, cubic bezier, F-spline.
              • fredo6F Offline
                fredo6
                In a last resort, could you clean up the plugin directory for everything starting with bezierspline_ and BZ_ (file and folders), and then reinstall the latest version from the Sketchucation ExtensionStore...
                  Bluewater77
                  I uninstalled the extension then reinstalled it before. I will try what you suggested. Thanks
