    Can't Impose Grid with Flowify
    3 Posts 2 Posters 2.1k Views 2 Watching
    • A
      Amirashraf
      😐 😐 ]hi. im tring to impose the component to a cuved suface, what i am actually to achive here is to make a diagrid structure along the curved surface. can anyone help
      help please.. thank you very much
      trying to achieve something like this, but on curved surface
        Else you can't flowify a volume around a total circular surface! ❗
        Just make a vertical dilatation gap and all will works fine! πŸ€“
        (as in reality πŸ˜‰
        And last little trick : draw your target surface/ group it immediatly
        Draw your 2 lines / / group it immediatly
        If you don't make that you have all luck to have your 2 lines trimed somewhere by the target surface!
        (like in your example where lines are in the same plane of the surface's top ! πŸ˜‰
        And your last error! πŸ˜‰
        The volume must be a unic group and not a group of many groups! ❗
          Maybe you must try Flowify or Shape Bender
