    Visible layer pickboxes in skp 2019
    2 Posts 2 Posters 1.2k Views 2 Watching
    • P Offline
      pipingguy
      I would love to use my 2019 version. However, the subject items have been made smaller (in the shape of an eye) and they were moved to the left edge of the tool tray. Up thru 2018, the pickboxes were big and on the right side of the tray. I hope Trimble can change the new config back to the way it used to be. I always park my skp 2018 layer tray on the upper left corner of my screen and the short pointer travel distance to the big pickboxes is fine because they are closer to the middle of the screen. The 2019 design slows my workflow and adds a degree of frustration.
      • pbacotP Offline
        I've had some of these changes become annoying as in other software. I usually find I get used to it and don't notice once my muscle memory adjusts. That said the lackluster revamp of the layer window is sad. Try a mouse software that allows you to speed up your cursor movement. Once you get used to that it's even better.
