    SU runs slow
    5 Posts 3 Posters 1.3k Views 3 Watching
    • P
      PElgin
      I am having a problem with SU running slow when downloading and selecting a model. This model is relatively low poly, 3828, so shouldn't hang up the system. However, I notice it has 406 component definitions and 534 materials. This model was taken from a model that had many components so I suspect the problem is all this extraneous digital material. Is this correct? If so, how do I purge the extra stuff? Thanks, Pico
      • soloS
        solo
        https://sketchucation.com/forums/viewtopic.php?f=323&t=22920
        There is an updated version in the store, it is free
        http://www.solos-art.com
        • P
          PElgin
          Thanks , I'll give it a shot.
          • P
            PElgin
            Thanks for the tip! That works fantastically well.
            • sketch3d.deS
              sketch3d.de
              @pelgin said:
              ...it has 406 component definitions and 534 materials.
              close the 'Outliner' and 'Material' tab if opening a file is slow.
