    Advanced component attributes - view
    4 Posts 2 Posters 937 Views 2 Watching
      JonesRose
      Hello everyone!
      I am trying to use the advanced attributes available for components, specifically the price and size attributes............. Is it possible to set the entity info window in tray to see this info? I can only see those attributes when I create the component, not when I click on a component I have already created.............
      Any help is appreciated!!
        shawb
        The advanced attributes can be accessed within the Entity Info panel by clicking on the button highlighted in red in the attached screenshot. I believe this is what you are looking for. The price etc. values can be changed/added after the initial component creation and will affect all instances of the component.
          JonesRose
          Thanks! For some reason I do not have the little "Expander" button on that panel of the tray............. I am trying to figure out how to make it show up!
            shawb
            I should have added that you may need to grab the bottom edge of the panel and pull it down to expose the button. Apologies! On checking, it would seem that the entity info tray panel is the only one (panel with expander button) where the said button is not located at the top of the panel and will therefore not always be visible.
