    Error in Profile builder 3
    6 Posts 3 Posters 3.9k Views 3 Watching
    • deaneauD Offline
      deaneau
      Profile Builder produces an error
      in the secound picture: PB3 will not work with profiles 1-1-7mm. At 1,8mm the profile is broken.
      thank you
      https://1drv.ms/u/s!AoU3tpJxqmvto3fSKunVxf4ndQQ7?e=JRWFhG
      https://i.ibb.co/J2KfK3c/2019-08-19-11h19-58.png
      https://i.ibb.co/HHHyr17/2019-08-19-11h48-09.png
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
      • pbacotP Offline
        Could this be the small face limitation in SketchUp not PB. Try: Make a component of your work. Make a copy of the component and scale up 1000x. Perform the operation on the big copy of the component. Check that changes were made correctly in the original instance of the component.
        • deaneauD Offline
          deaneau
          ProfileBuilder2 have not this problem (1mm profil in the foreground)
          • W Offline
            Whaat
            Can you try changing the extrude mode to Follow Me? You might get better results.
            Can you please post the SKP file so I can test it? A lot of extrusion improvements were made in PB3 but there are some unusual situations that could give you strange results (eg. very small profiles combined with certain types of extrusion paths)
            Thank you very much for the feedback
            • deaneauD Offline
              deaneau
              https://1drv.ms/u/s!AoU3tpJxqmvto3fSKunVxf4ndQQ7?e=7lI2in
              • W Offline
                Whaat
                I'm not sure why PB2 worked, but PB3 has trouble with this due to a combination of the small scale of the model and also the type of path. There seems to be an issue with PB3 when extruding along a circular path where the path's axis is horizontal. The issue will not always occur. It depends on a number of things so this is somewhat of a corner-case that you have discovered.
                We have logged this issue and will try to fix it in a future update. Thank you for bringing it to our attention.
                As a workaround, avoid using very small profiles and try not to extrude around a circular path that has a horizontal axis.  It will more likely work if you extrude along a circular path where the axis of the circle points vertical.  Then, after creating the Profile Member, rotate it and move it into the proper position.
