    Exporting standard views into JPG-Files
    extensions
    6 Posts 2 Posters 3.7k Views 2 Watching
    • sting2318S Offline
      sting2318
      I want to do this:
      I want but to export the six standard views into jpgs-files.
      This views are the wellkown ISO, FRONT, BEHIND, TOP, RIGHT, LEFT
      Before saving each view it should make a SHOW ALL so that the complete model is visible.
      The directory should be the same as SKP-directory.
      I need a one-click solution or a ruby file (second best solution) that I can execute in the console.
      How can I achieve this?
      Any idea or solution?
      Thank you in advance.
      • jujuJ Offline
        juju
        SceneExporterPro
          sting2318
          Thank you for the hint; I checked this toll but it first of all requires the manual creation of views!
          What I want is a one click solution or ruby script that saves the 6 standard views into 6 jpg-files.
          • jujuJ Offline
            juju
            AFAIK you will always have to create / define views, how else will SU know where it is supposed to point?
              sting2318
              You are right of course, views are required.
              From my point of view, the script can automatically generate the 6 required views, then export the JPG files.
              It should just be done within acouple of seconds with a single command, means without running through the commands manually.
              I think this is not a big issue for a ruby-developer knowing the API-calls.
                sting2318
                I therefore offer the first programmer who programmed this script 50 USD, via Paypal or bank transfer!
                Who is willing an able to build this?
