    [Plugin] [$] s4u MultiSlice
    14 Posts 7 Posters 7.6k Views 7 Watching
    • hdpvH
      hdpv
      s4u MultiSlice v1.0.0
      Multi Slice,Cut,Detach Selected Objects(Faces,Groups or Components).
      Suforyou
      http://www.sketchupforyou.com
      • srxS
        srx
        Is this an upgrade to SU4You Slice plugin?
        www.saurus.rs
        • hdpvH
          hdpv
          this is the new plugin.
          Suforyou
          • D
            dtrarch
            Hi VI
            Just a super improvement.
            Bread and butter for everyday use.
            How about a MULTI PATH version.?
            Draw path and then slice
            • hdpvH
              hdpv
              Hi Dave!
              Draw path and Double click or Enter or Select First Point for Close Selection.
              Suforyou
              • G
                glro
                i was looking for a plugin that would select components inside a closed contour
                for example the components closest to the tank
                scaffold around a circular tank
                but this plugin does not select, it cuts along the contour
                would it be possible to add an option "select without cutting?"
                the native selecting box is rectangular only, and in some cases, it is not sufficient
                • hdpvH
                  hdpv
                  Hi Glro!
                  I plan do a new plugin for this issue. s4u_Crop_Selection,
                  Select objects within Polyline ,Window and invert selection.
                  Suforyou
                  • D
                    dtrarch
                    Thanks Vi 👍
                    Dave
                    • G
                      glro
                      @hdpv said:
                      Hi Glro!
                      good news !
                      this function is missing in sketchup
                      components totally inside the volume corresponding to the polyline projected on the perpendicular axis would be selected, just as the native function does it with a rectangle
                      the volume could also be based on a circle, instead of a polyline
                      waitng for s4u_Crop_Selection
                      • LAUFERONL
                        LAUFERON
                        Very useful plugin.
                        Is there a way to keep edges after cutting ?
                        The component loses its volume properties.
                        Redrawing lines "a la mano" of course... May be an automatic solution ?
                        Thanks for your job
                        Bruno
                        • Dav_IDD
                          Dav_ID
                          Hi there and happy new year !
                          Just few questions about really this cool tool :
                          I've tried it, but i had not enough time to try it before it expired
                          so,
                          Someone here know if it's possible to
                          1. add positive value (recovery) when cutting a component (like in SU4Panel)
                          2. add negative value (saw kerf) when cutting a component (like in SU4Panel)
                          3. add face to the section (after cutting)
                            ... and eventually
                          4. cutting perpendicularly (normal) while being on 3D view ?
                          Thanks a lot !
                          David
                          • JonFarJ
                            JonFar
                            hi
                            I don't get how you do that last cut in the video
                            How does it snap to slice(or detach) right at half?
                            When I try to do that it just slices the lines from the viewer perspective (like in the move before that)
                            thanks
                            • hdpvH
                              hdpv
                              Hold press Ctrl on Window ,Option on Mac
                              Suforyou
                              • JonFarJ
                                JonFar
                                thank you
                                sorry to bother you again, just one last question:
                                when I do that, it works almost perfect.. it just doesn't create any faces on the slices...
                                am I doing something wrong?
                                I have 'add section faces' on...
