    [Plugin] [$] s4u MultiSlice
    14 Posts 7 Posters 7.6k Views 7 Watching
    • srxS Offline
      srx
      Is this an upgrade to SU4You Slice plugin?
      www.saurus.rs
      • hdpvH Offline
        hdpv
        this is the new plugin.
        Suforyou
        http://www.sketchupforyou.com
          dtrarch
          Hi VI
          Just a super improvement.
          Bread and butter for everyday use.
          How about a MULTI PATH version.?
          Draw path and then slice
          • hdpvH Offline
            hdpv
            Hi Dave!
            Draw path and Double click or Enter or Select First Point for Close Selection.
            Suforyou
              glro
              @hdpv said:
              s4u MultiSlice v1.0.0
              Multi Slice,Cut,Detach Selected Objects(Faces,Groups or Components).
              i was looking for a plugin that would select components inside a closed contour
              for example the components closest to the tank
              scaffold around a circular tank
              but this plugin does not select, it cuts along the contour
              would it be possible to add an option "select without cutting?"
              the native selecting box is rectangular only, and in some cases, it is not sufficient
              • hdpvH Offline
                hdpv
                Hi Glro!
                I plan do a new plugin for this issue. s4u_Crop_Selection,
                Select objects within Polyline ,Window and invert selection.
                Suforyou
                  dtrarch
                  Thanks Vi 👍
                  Dave
                    glro
                    @hdpv said:
                    Hi Glro!
                    good news !
                    this function is missing in sketchup
                    components totally inside the volume corresponding to the polyline projected on the perpendicular axis would be selected, just as the native function does it with a rectangle
                    the volume could also be based on a circle, instead of a polyline
                    waitng for s4u_Crop_Selection
                    • LAUFERONL Offline
                      LAUFERON
                      Very useful plugin.
                      Is there a way to keep edges after cutting ?
                      The component loses its volume properties.
                      Redrawing lines "a la mano" of course... May be an automatic solution ?
                      Thanks for your job
                      Bruno
                      • Dav_IDD Offline
                        Dav_ID
                        Hi there and happy new year !
                        Just few questions about really this cool tool :
                        I've tried it, but i had not enough time to try it before it expired
                        so,
                        Someone here know if it's possible to
                        1. add positive value (recovery) when cutting a component (like in SU4Panel)
                        2. add negative value (saw kerf) when cutting a component (like in SU4Panel)
                        3. add face to the section (after cutting)
                          ... and eventually
                        4. cutting perpendicularly (normal) while being on 3D view ?
                        Thanks a lot !
                        David
                        • JonFarJ Offline
                          JonFar
                          hi
                          I don't get how you do that last cut in the video
                          How does it snap to slice(or detach) right at half?
                          When I try to do that it just slices the lines from the viewer perspective (like in the move before that)
                          thanks
                          • hdpvH Offline
                            hdpv
                            Hold press Ctrl on Window ,Option on Mac
                            Suforyou
                            • JonFarJ Offline
                              JonFar
                              thank you
                              sorry to bother you again, just one last question:
                              when I do that, it works almost perfect.. it just doesn't create any faces on the slices...
                              am I doing something wrong?
                              I have 'add section faces' on...
