    Order in Extensions menu
    3 Posts 2 Posters 6.6k Views 2 Watching
    • PixeroP Offline
      Pixero
      Just a quick question about what decides the order in the Extensions menu?
      It's not alphabetic thats for sure.
      • TIGT Online
        It is alphanumeric - and it is based on the name of each RB file that loads the code - the name of the menu item is not relevant.
        Native tools load before extensions in menus other than 'Extensions' [aka 'Plugins']
        So "Aardvark.rb" can create a menu item named "Zulu" near the start of the Extensions menu, while "Zyx.rb" will create an item named "Aaargh" near the end of the Extensions menu !
        If you make your own "Pixero" submenu within your module, and add everything under that submenu, then the items' order is set by the same loading order rules.
        • PixeroP Offline
          Pixero
          Thanks for clarifying it.
          I had a hard time finding my own plugin in the menu and thought something was wrong with the code. 🤣
