Impossible to make a circle
I set the scale in milimeter and inside a 1mm2 square I cannot make a circle.
It tells me the following error:
Thanks!!
It's a limitation that can be overcome, make it 10 or better 100 times bigger, then reduce it back, it will work.
Thanks!!
p.s. I saw what you do, that's amazing. Did you do all with skp? Even character of star wars modeling?
Register LoginAdvertisement
